fan blower motor
Old 08-01-2005, 03:27 AM
ryantatum20's Avatar
Default fan blower motor
Hello,
I have a few questions:
1. Where is the fan blower motor in the 1990 626LX
2. Is it a do it yourself replacement job?
3. Where can I get one for a good price?
Thanks in advance.
Old 08-08-2005, 08:26 PM
Default RE: fan blower motor
1. Blower motor is under the glovebox
2. Yes, you can three mounting screws & trim cover.
3. Aftermarket, but you usually have to cut the wire harness & exchange the blower fan. Wiring, stripped both wire end about 1/4"
the motor comes with connectors, only have to get the right turning direction. Blower fan, patience & two flat screwdrivers, pry
up on opposite sides.
Old 08-16-2005, 03:33 AM
Default RE: fan blower motor (one more tip)
Just thought I'd add to the good info gtxtreme has already given: make sure that the motor is actually what's bad before buying a new one.
If the fan operates on certain speeds but not others, you're probably looking at a bad blower motor resistor assembly (mounts in the same box as the blower motor) and not the actual motor. Even if it doesn't operate on any speed, its still a good idea to check that resistor first.
the_gray_mazda6
11-08-2013 04:27 PM
lockwoodm
08-12-2009 01:38 AM
kegroening
03-22-2008 06:32 AM
Psychofly
05-27-2007 08:23 PM
jday8400
06-21-2006 11:06 PM
Quick Reply: fan blower motor
