Mazda problem. Please help
Old 01-26-2016, 12:35 AM
Jesse223's Avatar
Default Mazda problem. Please help
I have a 2005 mazda 2.0L. . The check engine light is on. The code reader reads P2004, which mean that intake manifold runner conto stuck open in bank 1.
What do I do? Please help
Old 02-12-2016, 10:43 AM
eve6er69's Avatar
attached to this message is a picture from alldata of all possible things that can cause the issue.
Old 02-13-2016, 11:58 AM
Sparky202's Avatar
Two common things I've run into. First is the valve itself. The valve is vacuum controlled and the diaphragm develops a leak not allowing it to close. Second would be the solenoid that controls the valve. Easy enough to check the valve by applying vacuum to it.
There are two similar valves on the intake. One is easy to see, the other is under the throttle body. The one under the throttle body is the one your after.
Follow the vacuum line from it to the two solenoid's located right off the valve cover near the battery on the left side of the engine. Remove the hose to the valve at the solenoid and apply vacuum to the valve. If it doesn't move, it's the valve. If it does move with vacuum applied, very good possibility the solenoid that controls it is defective.
nic2bp
04-06-2011 08:59 PM
wahoowa90
08-09-2010 07:14 AM
jay604
10-03-2009 12:25 AM
loydster1
12-01-2007 02:43 AM
stewie
03-09-2007 07:16 PM
Quick Reply: Mazda problem. Please help
