Cyllinder Deactivation Eliminated in 2026
Old Apr 14, 2026 | 03:36 AM
  #41
nickswhip24's Avatar
i have the same egr setup on a 24' ce-i am with you on the oil change interval -i figured after a few years i would attempt to remove intake to check valves and replace pcv-with the egr it adds fun to the job
Old Apr 14, 2026 | 07:36 AM
  #42
JSchmo's Avatar
Yeah - removal of the EGR and intake just to get to the PCV sounds like "type 2 fun".
I'm guess now that I know the car has this deal too, I should add to my service plan to also do somewhat more frequent coolant drain and fills to keep internal corrosion at bay (30k or 3 years maybe???). Suppose this is something I could do.
For the transmission with the pendulum torque converter I will take your advice Calisto, I think you said every 15k drain/fill (which I can do) and every 30k pan drop to replace the filter (mechanic does this, over my pay grade).
Also am putting in a "top tier" gas mandate for my daughters to follow. With 3 of them sharing the car that's like corralling cats, but I will try. Maybe a shot of Techron in the tank before oils changes too (probably this a placebo since we are talking DI).
We should get a petition to Mazda on the CD to allow it to be user controlled. I'd even be happy with a software patch that deactivates it when Sport mode is engaged.
Old Apr 14, 2026 | 08:52 AM
  #43
Even on pre 2020 engine the PCV is not a fun task to clean. But thus far I have scoped enough post 2016 Skiactiv engine that I don't see an issue with the system at least up to around 170k miles. There is some small accumulation oi oil film that eventually coat the main body of the intake but as far as I can see it does not vaporize and continue into the combustion chamber enough to be alarming.
^^^^This is a very easy service to do with simple garage tools and a pair of RYNO Ramps ^^^^
Also am putting in a "top tier" gas mandate for my daughters to follow. With 3 of them sharing the car that's like corralling cats, but I will try. Maybe a shot of Techron in the tank before oils changes too (probably this a placebo since we are talking DI).It wont do anything for the base intake runner into the head but will do some positive results in the combustion chamber.
There is discussion about this on a thread not sure where. I would hold out and watch for a ECU update for Mazda or an aftermarket program offered to adjust this feature that some Mazda have to suit your control of that system. Watch for upcoming not programs from Versa Tuner
Copwtrips
Aug 30, 2024 10:14 AM
Alex_123
Sep 8, 2023 10:45 PM
Sarah McBurney
Jun 2, 2021 04:58 AM
jklein
Oct 30, 2016 04:53 PM
