RX8 WHEELS ON MAZDA3
I finally put Rx8 wheels on my Mazda3i Touring.The road noise is a little louder than the stock set up but I think it looks better and handles better aswell (Running Falken p-225-40-zr18 for tires). Exhaust CAI are next but with holidays around the corner I'll have to wait.
http://s421.photobucket.com/albums/p...100_1017-1.jpg |
RE: RX8 WHEELS ON MAZDA3
What does that mean for thelazy! I had trouble last night trying to get pic to post. Was it really that hard for you to click on the link!
I put winter tires on my mazdaspeed3 today and they are rubbing on the fender flair of the car when the suspension bottoms out. I got a really good deal on my wheels that came off a RX8 and am trying to figure out if there is an easy fix for the rubbing? I went from 215/45/18 to 225-50-17 so there is only 10mm change in width and 1/8th inch bigger in radius?
any ideas? |
djdaleman,
My tires on my RX-8 wheels are 225-40-zr18 and I have no rubbing even when I turn the wheels lock to lock. If your RX-8 wheels with the 215-45-18 are rubbing go with 40 instead of 45. There could be a difference between the suspension set upof your ms3 and my mazda 3. Vince |
I ran 225/45ZR17 on my Mazda3 on 17x7 wheels 60mm offset with no problems.
What size are the wheels you bought. Are they stock RX-8 wheels or were they aftermarket? |
they are aftermarket steel rims. the tires just are wide enough to not clear the fender flair so there is about 2" of travel before the tire hits. I didn't know if there is a suspension adjustment or something that I can do to prevent the wheel from rubbing.
the winter tires that I put on are 225/50/17 my stock tires where 215/45/18. thanks |
I suspect the wheels you got are not necessarily the right offset for your car putting the tire close to the sheetmetal.
I run snow tires on my wife's car using stock Mazda6 wheels (I have 2 sets, 1 that came with the car, and another for the snow tires) They work great, look good, and can be had for fairly cheap if you can find someone selling a set. |
I thought that the offset would have been the same for the RX8. it was a kijiji find from a small garage so I'm not too upset about it but I don't like the fact of having it rub when I hit big bumps... that is why I was wondering if there is anything that I can doo other then different rims or rubber?
ORIGINAL: vlstellato What does that mean for thelazy! I had trouble last night trying to get pic to post. Was it really that hard for you to click on the link! |
