Grating sound when running 2015 Mazda 3
Hiya,
My 2015 Petrol Mazda 3 has recently started making a grating sound when the engine's running. I've attached a video of this showing the sound. Does anyone know what the problem might be? When the engine's hot the sound still persists and is accompanied by a squeaking sound coming from the area around the serpentine belt. I also have a video of this attached below.
Other symptoms are that the engine area gets really hot during the drive, but no warning lights come on. I can only sense the heat when I look under the bonnet. Air conditioning also does not work very well. From googling the best explanation I could find was that the serpentine belt or associated system is worn/old and this is affecting water pump and air-con function, which explains the heat under the bonnet and the bad air-con. The belt appears to be in good shape - no cracking or fraying that I can see so I assume it's the surrounding system. Does this fit with issues/experiences other folks have had with their Mazda 3?
The car is fairly old, approximately 82k miles. Engine oil is within the correct levels so doesn't appear to be that.
Sasso
Mar 4, 2022 01:40 AM
