random thread to talk about whatever
Old Jul 24, 2008 | 08:57 AM
  #1351
UrbanmanUSA's Avatar
Default RE: Random Chat Thread
From a pure MPG standpoint, wouldn't you want as much tire pressure as possible in every tire to reduce rolling resistance?
My tires say max 44 psi. Allowing a 15% factor for cold versus hot (the air in tires heats up as you drive, as I'm sure you all know), I would want to put at most 38 psi cold in any tire (1/1.15 x 44). Does this calc make sense?
Now, I have heard some in this time of high fuel prices pump their tires up to 60 and 70 psi in an effort to max the reduction in rolling resistance. Even if the tire can safely take this (big if, imo), I would think there would be a great sacrifice in handling/grip and maybe even ride (your basically riding around on rocks if the tires have that much air in them).
Old Jul 24, 2008 | 11:22 AM
  #1352
sstlaure's Avatar
I would never exceed the maximum recommended tire pressure.
Yes, increased tire pressure reduces rolling resistance, it will also cause your tires to balloon. An over-inflated tire with wear out the tread in the middle of the tire before the rest of the tire. Your contact patch with the road would also get narrower as the outer treads lose contact with the road due to ballooning.
Your ride quality would also decrease as there would be less give in the tire to absorb minor road vibrations.
Old Jul 24, 2008 | 12:26 PM
  #1353
VB's Avatar
VB
ORIGINAL: sstlaure
I've dropped down to 30F/30R for now, actually...the recommened PSI for these tires.
Old Jul 24, 2008 | 06:02 PM
  #1354
That can't be the max for the tire, but probably the recommended psi by the manufacturer (Chevy) for the Bu.I have always found mnf's suggested pressures too soft.
Try pumping up the front to 34 and see how the car handles. (<<< Suggestion only.)
Old Jul 25, 2008 | 02:08 AM
  #1355
VB's Avatar
VB
ORIGINAL: virgin1
That can't be the max for the tire, but probably the recommended psi by the manufacturer (Chevy) for the Bu. I have always found mnf's suggested pressures too soft.
It's worth a shot. I'll try it tomorrow before work.
Old Jul 29, 2008 | 06:05 PM
  #1356
ELSALV39's Avatar
cant post!!!!!!!!!!!
Old Jul 29, 2008 | 06:06 PM
  #1357
ELSALV39's Avatar
[:@]maybe now!! doing fine after 5.4 earthquake that hit here in southern california.[8D]
Old Aug 20, 2008 | 07:08 AM
  #1358
jaimie08mazda3's Avatar
so im bored. hmmmm
Old Aug 20, 2008 | 10:43 AM
  #1359
SPeeDy3's Avatar
hey guys
Old Aug 20, 2008 | 08:05 PM
  #1360
HOLY **** SPEEDY LIVES. i was just wondering where the **** you went!
