mazda etude
I agree 150% there bro..aircooled Volkswagens can be a real pain in the *** when it comes to mechanic them,i had one when i was a student...it took up all my time and money so i got rid of it..Thats why i feel this way about my girlfriends car,and as i said it's not the brand it's the way you get helped at the mazda agents over here..well enough said,beter we leave it there i don't wane start a dabet over it believe me its not my intension...I need some help with the car...please..i am out of ideas
Not sure if it's an interference engine or not.
If you did a compression check and it showed even compression between all cylinders, I'd say the valves aren't bent.
Double check to make sure the valves aren't 180 degrees out of time.
I've built engines...and entire vehicles - it's not hard to miss that. I've had vehicles I had checked numerous times for timing and not fire turn out to be 180 degrees out. During the 4-stroke cycle their are 2 TDC positions for the piston.
I have done that as well,the crank's timing mark and the camshafts mark's are dead on.There's an i and an e on top of the cams they are facing topwards the marks on the cams pulleys are facing each other when its at tdc.Its a 16valve 1.6 b6 motor.According to the workshopmanaul the inlet and outlet notches should face outwards on the tdc for the fire cycle on the no 1 piston.What boders me is that when the the motor is in this cycle the pick up on the crankpulley,there are 4 of them one for each piston to detect fire timing,is about 1/4 way away from the sencor.The pulley can only go on 1 way.All the wires can go on one way.What i have found is that there's a earthstrap on the engine mounting hanging loose,i haven't yet had time to see if this could be the problem but i will try again over the weekend.What do you think?
