2002 MAZDA TRIBUTE Milky coolant, no engine oil or trans fluid contamination
Old Dec 29, 2023 | 09:15 PM
CUCO01's Avatar
Default 2002 MAZDA TRIBUTE Milky coolant, no engine oil or trans fluid contamination
HELLO
The upper coolant hose raptured and as I was removing the hose I encountered a milky substance in the cooling system, no milky substance in the engine oil or the transmission fluid.. I doubled checked.. I removed the intake, spark plugs and the the valve covers and saw no signs of milky substance in the insides.. The timing chain and the camshafts look clean, took a look at the spark plug holes and no evidence of coolant or milky substance.. Has anyone experienced this.. I will be replacing radiator and the hoses and flush the cooling system.. Thank you in advanced..
Old Jan 5, 2024 | 04:40 AM
helendenizer's Avatar
Old Jan 5, 2024 | 10:29 AM
Welcome to the forum.
You should do a coolant chemical service test.
MazdaOwner5
Jan 3, 2023 12:51 PM
CScheids11
Feb 9, 2021 05:39 AM
chris.raymond
Nov 7, 2018 03:51 AM
Adeola Ajala
Jan 6, 2017 05:08 AM
Emma Iles
Mar 25, 2015 08:27 AM
