Dried yellow fluid in engine bay, CX-5 diesel
Old Nov 3, 2018 | 12:56 AM
chris.raymond's Avatar
Default Dried yellow fluid in engine bay, CX-5 diesel
Hi, after a long trip I did an oil change and notice an remnants of an explosion of yellow fluid in the engine bay (see attached photo)
Any ideas as to what it is? The coolant and brake fluid reservoirs are full so I don't think it is that. The car is going fine.
Chris
Old Nov 3, 2018 | 02:31 AM
Ooh dear, you have lost your coolant. Very common and very harmful issue. Seen this far too many times, resulting in engine damage. We replace a CX-5 diesel engine about every 2 to 3 weeks.
It's often caused by a faulty radiator cap.
Is your vehicle still under warranty?
I would recommend taking it to Mazda for, Pressure test of the radiator cap, pressure test of the cooling system, carry out a compression test, and vacuum tests.
Old Nov 3, 2018 | 06:48 AM
Thanks grim_reaper, very helpful. Yes, even though the coolant reservoir was full, when I checked the radiator itself, it was not. I think the reservoir must have overflowed when we were on a long hot drive (38 degrees celsius outside) and then for some reason did not suck the coolant back into the radiator when it cooled. Would this be due to a faulty radiator cap?
Chris
Old Nov 6, 2018 | 04:21 PM
Telboy's Avatar
Don't think faulty cap, looks like pressure build up, running too hot, possible head gasket?
Old Nov 7, 2018 | 03:51 AM
As mentioned previously, radiator cap failure is common. Get the cap pressure tested.
r.hewko@krusena
Jun 12, 2010 09:42 AM
SF2KProtege
Nov 11, 2009 07:06 AM
the_gray_mazda6
Detailing
20
Dec 15, 2007 09:33 AM
tony1853
Detailing
13
Mar 25, 2007 03:39 AM
