Window probs but with a difference (2006 1.8)
Old Oct 18, 2018 | 06:31 PM
Gowza's Avatar
Default Window probs but with a difference (2006 1.8)
Posted this in the newbies section but realised this is probably the better place for such a question - hope you good people can help...
Recently I shut the rear door to hear a tinkling sound which sounded like something coming loose and finding its way down the inside of the door. Then I noticed that rear window wouldnt work.
Shortly afterwards the same thing happened when closing the opposite rear door and that window stopped working too. Tonight my passenger shut their door only to hear a tinkling sound again...yep, I now only have the driver's side operating. None of the malfunctioning windows work from either the drivers panel or their own switch.
I know about the reset procedure and have used this when the battery has gone flat - this does not work here.
The window lock button has no effect.
The tinkling sound obviously means something has come apart internally and this will mean taking the panels off each door...before I do this have any of you folks experienced similar and could helpfully point me in the right direction?
Thanks in advance,
Gowza
Old Oct 19, 2018 | 01:39 AM
You will need to remove the door cards and investigate.
Old Oct 19, 2018 | 06:16 AM
Gowza's Avatar
Thanks, I knew that'd have to happen, just hoped for some pointers from others who may have experienced the same.
Gowza
Oct 18, 2018 06:21 PM
1993 Mazda 323 BC Guy
Oct 19, 2016 02:49 AM
HerrKaLeun
Aug 4, 2013 08:34 PM
cgstone
Jul 1, 2006 01:29 PM
juju
May 6, 2006 08:59 PM
