Water Pump & belt, serpentine belt, belt tensioner, thermostat, valve cover + oil con
Old Jul 24, 2021 | 05:54 PM
footprintsinconc's Avatar
Default Water Pump, belts + tensioner, thermostat, valve cover, plugs, brake fluid change
Hi. i knew that this day would be coming when i would have a bunch of repairs that will pile up
I have about 115k mile and I've been seeing oil on the oil filter & drain plug access cover when i go to do the oil change...but then one day the car making the really bad squeaking sound when ever i started the car or accelerated.
So i started looking for the source and in the process i discovered three things:
1) belt tension had failed and leaked oil
2) that the valve cover + oil control valve was leaking oil and
3) i noticed a small leak had developed at the water pump
I went about to fixing these issues and some other over due items all at one time...I've recorded my work and here are the videos for reference. I split the videos into smaller pieces to make it more relevant.
  • belts
  • belt tensioner
  • water pump
  • thermostat
  • coolant drain and refill
  • spark plugs
  • valve cover gasket
  • brake fluid flush & refill
  • clean in take and throttle body clean
How to Jack up the car and support on stands:
Changing out the belts: water pump and serpentine belt
replacing the belt tensioner:
replacing water pump and coolant:
replacing thermostat:
replacing spark plugs:
replacing the valve cover and oil control valve gasket:
brake fluid flush and replace:
I did the oil change and tire rotation while at it, so had to reset the service reminder notification as well.
resetting the service reminder notification:
check out my other videos on the mazda 6:
https://youtube.com/playlist?list=PL...lMyuKkCNfkbEX1
Thank you !
Last edited by footprintsinconc; Jul 25, 2021 at 01:10 PM. Reason: title name edit
Jbmazda
Jul 3, 2018 11:01 AM
Parepin
Nov 27, 2014 08:02 AM
Doug Lassiter
Oct 11, 2013 08:09 AM
93greenstrat
Apr 15, 2013 04:09 PM
chuck225
Oct 6, 2010 11:03 PM
