Supercharger kit for 3.0L 6's
Old Oct 4, 2009 | 02:39 PM
CKeffer's Avatar
Default Supercharger kit for 3.0L 6's
Supercharger is finished, they are working of the timing & A/F maps currently. Full kit should be out soon. Those who are interested can follow the progress here.
-Cameron Keffer
Old Oct 4, 2009 | 08:01 PM
Hmmmm?
Old Oct 4, 2009 | 08:26 PM
CKeffer's Avatar
Roots type supercharger, they have it all machined to mate up to out engine, The Great NewYork is working on the tuning maps using the tuner he has tested out for us and is currently using on his own car running a twin turbo setup. Figured there might be a few on here that might be interested in this.
Old Oct 13, 2009 | 10:48 PM
CKeffer's Avatar
Update:
The kit uses a 4th Generation Magnuson supercharger which has self contained oil system and is capable of making 450 hp output. The CNC machined aluminum intake sandwiches a large aftercooler for lower boost temps and comes with a full pulley kit with new belts.
**(requires a new custom hood available and fits all transmissions)**
Kit Includes:
* Magnuson MP90 4th Gen. 450 hp maximum output
* CNC Custom Aluminum Lower Intake Manifold
* 3" x 12" x 1.75" Aftercooler
* Core Size: 11"x4.75"x2" 16 Row Heat Exchanger
* 2.9 GPM Intercooler Water Pump
* -6an braided water lines
* Pulley Plate with new sized belts
* Custom Plenum utilizing EGR, IAC, & vacuum distribution using OEM TB
* All bolts, clamps, & hardware included
PRICE: $4,995.00
Do not freak out about the price. It was set high as its easier to refund money, whereas if it set to low and winds up being more, the lower price has to be honored.
This is the vendor's current site.
Old Oct 21, 2009 | 12:54 PM
nyinthabuilding05's Avatar
The price of this actually went down. The base kit is going to be set around low 4k range. But have options to upgrade to a larger heat exchanger , higher psi pulleys and etc as well as larger injectors.
As cam said the tuning will be taken care of by me.
This setups base kit will be running 4psi which should net about 325bhp or so with pulley upgrade offering of 7-8psi and 11-12psi iirc without checking back.
The actual sc being used for the setup is good enough to flow approx. 450hp or so depending on tune
This setup wil be fully direct bolt on but will require the use of a modded hood that will be offered as an addition with the sc kit ,or the individual can mod their own hood.
The hood is currently still being worked on but the SC is pretty much finished.
This kit will be a helluva kit and extensive r and d has gone into this to make this power adder and tuning solution come to life.
steelgoat
Jul 18, 2006 03:10 PM
madd__hoppz
Jan 28, 2006 08:02 PM
lostbethus
Jan 6, 2006 11:10 PM
ARCVN76
Aug 27, 2005 03:13 PM
cvillareal
Aug 6, 2005 05:09 PM
