self oil changes......
Old Sep 10, 2005 | 12:26 PM
the_gray_mazda6's Avatar
Default RE: self oil changes......
so you are saying that i will need a cap cover wrench then?
Old Sep 13, 2005 | 07:01 PM
bluebomberx's Avatar
You can convert the Mazda 6i to a spin-on oil filter instead of the cartridge. It utilizes parts from the Mazda 3i. The link below is a write up, with pictures, provided by the administrators of the Mazda 6 Tech website.
http://www.mazda6tech.com/index.php?...d=47&Itemid=49
Old Sep 13, 2005 | 10:56 PM
babyhuey's Avatar
The first time you change your oil on your v6 will be very tight and you may need some help getting it loose. I think they hire sumo wrestlers to put them on at the factory[sm=headbang.gif]. After that filter will only be on as tight as you make it. Lube the rubber filter gasket with a little oil and will not only seat better but will come off much easier at next oil change.
Old Sep 14, 2005 | 04:39 PM
shaolin's Avatar
i had no problem changing the oil myself on the 6
Old Jul 10, 2006 | 01:52 PM
grngiantbp's Avatar
Does changing the oil yourself void any of the manufacturers warranty?
I have a 2006 Mazda 6s (V6).
Also, any thoughts on using a synthetic oil rather than standard?
Thanks...
Old Jul 10, 2006 | 05:15 PM
AlyssaC's Avatar
Damn it, babyhuey always beats me to the answers that I know!
Old Jul 15, 2006 | 11:33 AM
mescin85's Avatar
no maan it will not void your warranty if u change your own oil. the V6 should be a spin off type filter only the V4 have a carthridge filter. but if u do a carthridge just make sure that u are screwing the cover on evenly because u can really mess up the filter cover n u gotta but a new one.
Old Jul 19, 2006 | 05:09 PM
stron's Avatar
Same topic, different angle,...
I'm planning on switching to Royal Purple motor oil this weekend and am wondering about the oil and air filters. Since I'm moving to a performance oil, I assume I should upgrade the filters as well. Any suggestions?
I plan on going to CAI in the coming months, but can't afford it right now. So, stick to air filters that fit into the stock housing.
Thanks.
Old Jul 20, 2006 | 11:48 AM
I've been using the K&N oil filter for a better filtration process... no complaints on it at all.
Old Apr 24, 2007 | 02:44 PM
djs2571's Avatar
I was told the warranty holds as long as you keep your reciepts for oil/filter and such. You can also get a universal oil filter wrench at most auto places that works well enough.
