PCV Valve Removal
Old Sep 2, 2009 | 11:05 AM
93greenstrat's Avatar
Default PCV Valve Removal
How do you remove the old pcv valve (2006/V6)? I tried to twist it off by hand, but I'. getting nowhere.
Old Sep 2, 2009 | 02:28 PM
oldeng's Avatar
On my '99 1.8L Protege LX, the PCV valve is inserted into a big grommet, and you just pry or manhandle it out. I replace both the PCV valve and the grommet; take it with you when you buy the PCV. You're safe using auto parts replacements, and they sell the valves and the grommets too.
PS: Once it's out and cleaned up a bit, check if it rattles, and suck and blow on it to see if the check valve works; you may find there's nothing wrong with it. At the same time, check the hose condition (the hose is more prone to fail than the valve).
Old Sep 2, 2009 | 02:36 PM
Mazmart Trini's Avatar
You have to try & fit your hand between the firewall & intake manifold. The PCV valve twists out. It is a tight fit, but can be done w/o removing the intake manifold.
Old Sep 15, 2009 | 05:10 PM
k's Avatar
k
How many miles on your mazda6s? I plan to change it on 45,000 miles. What is part number on OEM PCV?
Old Sep 17, 2009 | 09:18 AM
Originally Posted by k
how many miles on your mazda6s? I plan to change it on 45,000 miles. What is part number on oem pcv?
ajc1-13-890a
Old Sep 17, 2009 | 02:40 PM
k's Avatar
k
Thanks, in mazda6club, someone said ajc1-13-890b.
What difference is Ajc1-13-890a and Ajc1-13-890b? Mine is 06 mazda 6s sedan. Which one is good?
Thanks
Old Sep 17, 2009 | 04:14 PM
There is no B from Mazda. The A is the most current.
-Sheldon.
Old Sep 19, 2009 | 12:16 PM
I have over 71,000 miles on it and this is the first time that I have changed the valve.
Old Sep 22, 2010 | 01:20 PM
Jeff6s2's Avatar
Smile Easy PCV Change Mazda 6 3.0
Had to change some parts this morning due to Engine Light and Emissions. "Lean Engine" Code. Cracked Air Box Hose and cracked PCV hose, figured I might as well change PCV while I was under the hood. Attempting to get at this valve isnt easy with the room given without removing the Intake Manifold.
**Heres The Trick**
I acquired some new 5/8" Hose (several feet too many at Home Depot). Removed Old Hose from old PCV Valve, cleaned oil off old Valve with a clean rag. Took a foot and a half length of the new TIGHT FITTING Hose and pressed it onto the old Valve to use as a Driver to turn the old Vavle out Counterclockwise...Then attatch the new Valve to the new length and install it...Trim to length, and DONE!
Hope this helps a few of You!
Old Sep 22, 2010 | 01:24 PM
Jeff6s2's Avatar
Forgot to mention, there is a locking tab which will need to be released by a flathead or other tool of Your choice.
jobless
Jan 10, 2012 07:25 PM
rochey32
Apr 4, 2011 04:43 PM
ChuckChuck
Oct 1, 2009 05:20 AM
cmares
Apr 5, 2007 06:12 PM
atlmw
Dec 6, 2006 04:20 PM
