Oil filter removal?
Old Jun 29, 2010 | 04:33 PM
bb62's Avatar
Default Oil filter removal?
I have a 2.3L Mazda 6 and I'm looking to change the oil. The oil has been drained but I can't seem to get the oil filter off. How do I do it?
Do I need a special tool?
Do I need to take the filter drain plug out first?
Old Jun 29, 2010 | 06:16 PM
It's recommended that you do both, but it's not necessary.
Draining the filter will make for a cleaner oil change but will NOT help remove the filter housing.
I never had the wrench, but used to use a soft-strap wrench, similar to this one I found on the web:
Your best bet is to convert to the 2.0L spin-on filter as I did.
It's much easier and safer... safer because that plastic filter housing can crack or break leaving you stranded.
Old Jun 30, 2010 | 07:28 AM
Mazmart Trini's Avatar
What Rich said. That is the best thing that you can do OP.
-Sheldon.
Jessev
Aug 6, 2021 10:03 AM
cdnen4cr
Apr 8, 2015 08:18 AM
JJohnsonAZ
Apr 9, 2011 07:18 PM
nctnwalkers
Jul 7, 2009 07:20 AM
