need help!
Old Feb 10, 2015 | 07:45 AM
banchee's Avatar
Unhappy need help!
i have a 2004 6 with a manual transmission, i removed a drain plug that i cannot find infor on. it is to the middle of the middle of the underside
and was a large torque bolt facing sideways,a redish fluid came out. above it in the engine compartment there is a large flat allen head fill bolt. please advise what fluid goes in and how much. i checked the haynes for fluid list and plug locations and cannot locate it. help is needed!!!!!!!!!!!!!!!
Old Feb 10, 2015 | 10:49 AM
hixx's Avatar
The trans fluid used is dependent on where you live actually. It says your in San Antonio so it would benefit from using a thicker oil than what it came with.
GL4 or GL5 (cold)
75-90 (moderate)
80-90 (above 50 degrees)
The hotter the environment the thicker the oil you want to use. If you use a thicker oil and it gets below 50 degrees then it will shift a little stiff until warmed up.
Old Feb 10, 2015 | 11:22 AM
banchee's Avatar
problem is, i am not sure this is transmission drain plug, most posts/internet
sites, claim near rad. with fill on top and drain on bottom, this is located left and below of brake master cylinder
Old Feb 10, 2015 | 01:27 PM
hixx's Avatar
If it has a spring and check ball in the hole it is for a shift rod detent. If it has a smaller diameter protrusion about 1 inch long then it holds reverse idler gear. If it is just flat with maybe a magnet on it it is likely a fill plug.
Old Feb 10, 2015 | 03:34 PM
banchee's Avatar
it is a large diameter with a torque bit head and standard theads,it is the fluid and the location that i am concerned about,the fill bolt in the engine bay above it is an allen head, if you look directly at the master cylinder, it is left and directly down about 12-14"
Old Feb 10, 2015 | 09:38 PM
hixx's Avatar
Why not just put the bolt back in, drain and refill the trans.
Old Feb 11, 2015 | 04:50 AM
See this diagram.
Old Feb 11, 2015 | 07:23 AM
banchee's Avatar
not sure what and how much fluid goes into this fill plug/drain .
Old Feb 11, 2015 | 09:43 AM
hixx's Avatar
Drain and refill is 3 quarts.
Old Feb 12, 2015 | 03:58 AM
Pour the new oil into the fill hole until It flows out.
Metalmunkeez
Jun 21, 2011 06:19 PM
Stevoh
Jun 21, 2010 03:17 AM
