mazda 626 1999 engine shakes in drive idle HELP
Old Oct 24, 2010 | 07:45 AM
Kurt's Avatar
Default mazda 626 1999 engine shakes in drive idle HELP
1999 mazda 626 2.0L 4cyl engine shakes horribly in idle in drive. have to put car in neutral when at traffic light..... changed spark plugs wires valve cover gasket (it was leaking), air filter, changed oil.... still shakes, not quite as bad, but still shakes... HELP!!
Old Feb 26, 2011 | 07:59 PM
TonyL's Avatar
Wink Engine shakes
Possibly vacuum leak is causing shake check intake manifold gasket,check hoses,it may be a hose disconnected
Old Feb 26, 2011 | 08:47 PM
ggsumo's Avatar
what colour were the plugs you took out?
Are you using oil or fluids?
Does it run OK when moving?
When was it last services and was the fuel filter changed?
Old Mar 4, 2011 | 07:16 AM
scott1616's Avatar
egr valve probably
Old Mar 4, 2011 | 11:47 AM
mazdaenthusiast's Avatar
Default engine misfiring problem
looks like it is an engine misfiring problem. the probable causes of misfiring are damaged distributor cap, spark plug, or a burnt out valve.
mazdita
Jul 31, 2011 09:25 AM
gumpertz
Jan 17, 2009 10:02 PM
auranissa
Nov 3, 2007 09:42 AM
Sploogius
May 23, 2007 02:01 PM
mitseclipse786
Jan 18, 2007 08:52 PM
