mazda 626 1999 engine shakes in drive idle HELP
1999 mazda 626 2.0L 4cyl engine shakes horribly in idle in drive. have to put car in neutral when at traffic light..... changed spark plugs wires valve cover gasket (it was leaking), air filter, changed oil.... still shakes, not quite as bad, but still shakes... HELP!!
Engine shakes
Possibly vacuum leak is causing shake check intake manifold gasket,check hoses,it may be a hose disconnected
what colour were the plugs you took out?
Are you using oil or fluids? Does it run OK when moving? When was it last services and was the fuel filter changed? |
egr valve probably
engine misfiring problem
Originally Posted by Kurt
(Post 112553)
