Mazda 6 sport 2009 2.0 diesel
Old Sep 26, 2019 | 05:23 PM
T10068's Avatar
Default Mazda 6 sport 2009 2.0 diesel
Hi everyone im going to keep this short as i can and hope that someone can recognise this problem. I have s Mazda 6 sport 2.0 diesel with a major problem ill start from the beginning. It all started when the engine gave in the "dreaded injector issue", so off i went and sourced a second hand engine from a breakers and got my mechanic to install it. After he installed said engine and done all the checks he started the car and it ran no problem first time. The major problem is it will not respond to throttle imput at all it just stays at idle or drops below it. We checked the injectors which were reconditiond and noticed the car is only running on two injectors at a time. First we taught the injectors might need to be coded but the car will not recognise the diognostics equipment and the only fault code we got was a u0401 code none comunication with ecu i think it might be somthing else. I have a sneaky feeling it is electric problem ie sensor, faulty wires from install or bad earth. Three lots of mechanics are after looking at it and all got bet on it. I hope some one that reads this can understand this problem and can shead some light on this thanks.
Old Sep 27, 2019 | 04:10 AM
When the engine was swapped, did they use all the sensors and wiring off your old engine?
The replaced injectors need to be programed to the old PCM, you can't get around this process.
You either need to find another workshop with a better diagnostic tool or tow it to Mazda and get them to program them.
Old Sep 27, 2019 | 02:37 PM
T10068's Avatar
Thanks for your reply and comments grimreaper, My mechanic said he swaped all or most of the sensors from old engine including the fuel pump with sensor to the new one. I think you might be right about the diognostics equipment they are using is not up to scratch i may aswell bite the bullit and send it to a mazda garage.Its turning into a never ending money pit. 😢
Rattler
Aug 13, 2018 06:55 AM
Liz Steele
Jun 25, 2018 04:35 AM
scallaghan99
Jan 31, 2014 03:27 AM
Nigel Henry
Jan 26, 2012 12:10 PM
landlord
Jan 9, 2011 07:33 AM
