mass air flow problems Mazda 6 2.0 Diesel
Looking for advice with a mass air flow sensor problem i have.
This started a few weeks ago the car would intermittently run rough loose power and smoke badly, i scaned for codes and got P0104 Mass Air Flow Sensor A Circuit Intermittent.
I have fitted a new sensor OEM quality but still have the same problem.
Any advice would be greatly appreciated.
2008 Mazda 6 ts2 2.0 ltr Diesel
DTC P0104
Mass airflow (MAF) sensor circuit malfunction
DETECTION CONDITION
• The PCM monitors the input signal from MAF sensor. If the voltage of the MAF sensor is out of the threshold for 60 s or more, the PCM determines that there is a malfunction in MAF sensor.
POSSIBLE CAUSE
• Intake air system malfunction
• MAF sensor malfunction
• Connector or terminal malfunction
• PCM malfunction
DETECTION CONDITION
POSSIBLE CAUSE
• PCM malfunction
I would greatly appreciate you response!
GlowingPiston
09-30-2017 04:15 PM
