mass air flow problems Mazda 6 2.0 Diesel
Looking for advice with a mass air flow sensor problem i have.
This started a few weeks ago the car would intermittently run rough loose power and smoke badly, i scaned for codes and got P0104 Mass Air Flow Sensor A Circuit Intermittent. I have fitted a new sensor OEM quality but still have the same problem. Any advice would be greatly appreciated. 2008 Mazda 6 ts2 2.0 ltr Diesel |
DTC P0104
Mass airflow (MAF) sensor circuit malfunction DETECTION CONDITION • The PCM monitors the input signal from MAF sensor. If the voltage of the MAF sensor is out of the threshold for 60 s or more, the PCM determines that there is a malfunction in MAF sensor. POSSIBLE CAUSE • Intake air system malfunction • MAF sensor malfunction • Connector or terminal malfunction • PCM malfunction |
Originally Posted by maz654
(Post 173685)
(Post 173685)
This started a few weeks ago the car would intermittently run rough loose power and smoke badly, i scaned for codes and got P0104 Mass Air Flow Sensor A Circuit Intermittent. I have fitted a new sensor OEM quality but still have the same problem. Any advice would be greatly appreciated. 2008 Mazda 6 ts2 2.0 ltr Diesel I would greatly appreciate you response! |
