key fob not working
Old Sep 18, 2012 | 07:59 PM
Victor520's Avatar
Default key fob not working
I have replaced the battery in my Mazda key fob, but still no response on ingnition, door locks etc... the red light on the fob flashes, but nothing will operate... do I have to reprogram?
Old Sep 18, 2012 | 10:35 PM
MazdaTirol's Avatar
It does sound like it just needs to be re-paired to the car, there might/should be the instructions in your owners manual on how to do that.
Old Sep 19, 2012 | 07:16 AM
Mazmart Trini's Avatar
This. The fob will have to be reprogrammed.
"Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks."
Old Sep 19, 2012 | 11:29 AM
Talking
EXCELLENT! I have copied and pasted this in to a word document in my Mazda Section for future use!.
Old Oct 8, 2012 | 01:18 AM
Victor520's Avatar
Thank you for you help, and i found a tool Link removed by MazdaForum staff does it can help me?
Last edited by MazdaTirol; Oct 8, 2012 at 06:30 AM. Reason: Removed Questionable Link
Old Oct 8, 2012 | 06:36 AM
MazdaTirol's Avatar
I removed the link you posted for the safety of your members, it was directing members to a Chinese website we had already deemed unsafe.
Did you try the suggestion that Mazmart Trini offered?
Old Oct 8, 2012 | 06:57 AM
Victor520's Avatar
oh i am sorry, yes i have try , but it didn't work
Old Oct 8, 2012 | 07:26 AM
MazdaTirol's Avatar
Have you tried to "reset" the car itself by unhooking the battery? Also are you trying to use the fob in an area of high electro-magnetic interference (high voltage power lines e.t.c.) since that can severely reduce the range if not keep the car from receiving signals all together.
Old Oct 15, 2012 | 09:55 PM
Victor520's Avatar
yes it work i have solve it with your help! thank you very much
Old Jan 1, 2015 | 01:49 PM
nikhoop26's Avatar
I tried this as my key won't work either but the doors will not lock or unlock manually while the door is open
