Horns power wire color at the relay-fuses box
Old Sep 30, 2021 | 09:39 PM
jean-marc's Avatar
Unhappy Horns power wire color at the relay-fuses box
Hello to all; I have a intermittent short with the horns on my Mazda 6 2007 . I know the wires AT the horns are green-yellow but which wire color is at the Relays-fuses box inside the engine comp ? The fuse 20Amp (stop fuse ) open sometime , intermittent . I want to follow the wire from the relay-fuses box in engine ;I saw a diagram saying that the wire should be Violet- white , but there is no wire this color at the relay box rectangular large connector on left side. Does somebody knows which wire there is the one carrying power for the horns ? Many Thanks for your help . JM
Old Oct 2, 2021 | 01:29 PM
Mazdaon's Avatar
I've found the horn diagram and the color of the wire to the STOP fuse box is Green/White, it's so wrong for Mazda to use only one fuse for both sides of the relay.
Old Oct 2, 2021 | 06:51 PM
jean-marc's Avatar
Thanks MazdaOn, but I do not see any Green-White wire on the connector at the relay -fuse box... I wonder if it arrives this color on the bottom of the connector (wires bunch ) , and then change to another one ? Non-sense to me... but ... ?? I am lost...
Old Oct 3, 2021 | 03:01 PM
Mazdaon's Avatar
Probably because Grn/Wht don't leave the fuse box, they're internal wires.
Is everything working in the steering wheel? e.g, cruise control, audio controls, etc. Any failure or intermittent issue of those switches would indicate a damage ClockSpring.
Old Oct 4, 2021 | 10:10 PM
jean-marc's Avatar
Thanks , but nothing wrong at the steering wheel ; I am just trying to follow the wires from the horns in front (green-yellow wires ) To : the relays box; I am unable to locate these green-yellow wires at the fuses-relays box...
Tireman9
Mazda CX-30
May 4, 2021 02:06 PM
kaos813
Sep 7, 2019 06:27 AM
liftedtrucks4me
Apr 29, 2012 02:07 PM
jaimie08mazda3
Jan 31, 2012 08:15 AM
ripcbx
Apr 7, 2006 08:16 PM
