EGR valve
Old Sep 4, 2016 | 10:47 AM
koli9's Avatar
Default EGR valve
Hi guys, from the title you can see that I have problem with the EGR valve.
I have a mazda 6 from 2004, diesel, with 2000cc engine.
I took my car to the service twice already to clean the valve, but after 2-3 days from cleaning, the errror code reappeares with the check engine light.
Do you have any of you ideas what to do? Or in the worst case i have to replace it with new one? Or there is something much worse in the background?
Thanks forward for your answers!
MAZDA is the best
Old Sep 5, 2016 | 03:06 AM
What fault codes are you getting?
Old Sep 5, 2016 | 03:59 AM
koli9's Avatar
I dont remember exactly what code is , but iam getting only one fault code and at the service i was told that is related to the EGR valve .
Old Oct 16, 2016 | 01:53 PM
koli9's Avatar
Hi I finally bought ELM 372 diagnose tool.
With it i could read the error codes and that is P0401 and P0402.
Insufficient flow if iam correct.
Any suggestions what could be the cause?
I already cleaned the EGR valve.
Old Oct 17, 2016 | 04:52 AM
P0401 : EGR flow insufficient detected
Possible causes,
• EGR valve malfunction
• Intake shutter valve malfunction
• Boost sensor malfunction
• EGR gasket malfunction
• PCM malfunction
P0402 : EGR flow excessive detected
Possible causes,
• PCM malfunction
When we use the IDS/MMDS ( Mazda's diagnostic software ) at work we can monitor multiple PIDS ( Parameter Information Display ??? )
We can switch the EGR valve on & off, or the Intake shutter valve on & off electronically & monitor multiple sensor outputs. This helps pinpoint problems without swapping out parts.
lynn
Mar 14, 2006 11:01 PM
ignantmike
Jan 29, 2006 09:58 PM
vizz
Jan 11, 2006 08:54 PM
ash26
Aug 16, 2005 01:34 PM
bigboostin
Jul 29, 2005 09:45 PM
