CEL after new plugs
Old Feb 20, 2016 | 03:30 PM
scott944's Avatar
Default CEL after new plugs
Changed the plugs in my 2010 6 4cyl this afternoon, along with cleaning the throttle body and dropping in new engine and cabin air filters. Plugs are Denso Iridium, carefully gapped to 0.040", per the instructions from the parts counter at my local Advance. Car fires right up and runs smooth as glass (125k miles, btw), but the CEL is on. Thoughts?
Old Feb 20, 2016 | 11:51 PM
Is everything plugged in properly?
Are you sure the spark plugs are the correct plugs? Do they look the same?
Disconnect the battery, press & hold the brake pedal for 5 minutes.
Make sure the ignition key is removed, all the lights are turned off & the doors are closed.
Re connect the Battery, start the car, make sure lights, radio, heater are all off, let it idle for 4 or 5 minutes, take it for a steady drive & see what happens.
Old Feb 21, 2016 | 02:24 PM
scott944's Avatar
Drove the car again this morning, for around half an hour, followed by an hour parked. Since then, the light is out and hasn't returned. My best guess is there was some TB cleaner still in the intake, fouling a sensor, that has finally burned off.
k
Dec 2, 2011 02:52 AM
republic47
May 25, 2011 12:54 PM
techsupport
Oct 4, 2010 07:45 PM
virgin1
Jun 16, 2010 08:19 PM
poet1234567
Jul 9, 2006 08:46 AM
