Anyone who knows the difference between the cat on 1.8 and 2.0
Old Jun 19, 2023 | 01:54 PM
Fotokille's Avatar
Default Anyone who knows the difference between the cat on 1.8 and 2.0
Have a big problem with the catalytic converter my mazda 6 2.0 2002 was stolen and I can't find a new one anywhere, but for 1.8 there are plenty of them Does anyone know what separates them, can I modify it to 1.8 so it fits my 2.0 or is it the cone with the manifold that differs, well really the only thing I can't modify
Old Jun 19, 2023 | 02:04 PM
The CAT internally in itself does the same thing there is no difference in the Emission at the tail pipe.
If you can modify it in a way that looks more or less factory most countries would except it. But I would not recommend to use any none OEM clamps and welding would be a better installation.
Old Jun 19, 2023 | 02:05 PM
Old Jun 19, 2023 | 02:09 PM
Fotokille's Avatar
Yes, welding and pipes are no problem, but the biggest concern is that the cone separates, well that's the only thing I have difficulty modifying
Old Jun 19, 2023 | 02:22 PM
I suggest to change your font color on some devices (like the one I am using at the moment I can barely read you response? ^^^^^^
Most exhaust that do separation are after the CAT so it may take a muffler shop to help you modify a OEM CAT. You are not bond to necessarily use only a MAZDA CAT as most are either 2 way or 3 way CAT.
YOur year I believe (didnt look) is a 2 way so either will work. If yu had a 2014 or newer then it would be a 3 way and and 2 way CAT wouild not work .
UseYourNoggin
Jan 16, 2013 06:14 PM
Askme42
Nov 23, 2012 12:13 PM
mishian
Jun 18, 2012 07:45 PM
darkstar4100
Oct 3, 2010 08:40 PM
chatapuggy1
Sep 4, 2007 08:21 PM
