2010 mazda 6 battery light
Old Sep 11, 2020 | 02:00 PM
Armyrules2's Avatar
Default 2010 mazda 6 battery light
So my girlfriends 2010 mazda 6 died about a week ago. So I put a new battery, alternator, and belt in it. The car now runs fine but the battery light comes on periodically.
Old Sep 11, 2020 | 02:55 PM
First to do is the following:
Using a Diagnostic Tool connected to the Diagnostic connector under the drivers dash check for any DTC(s)
Double check that the battery terminal cables are clean and making good contact with the battery cable terminal.
Carefully look at and check the condition of the ground cable from the battery top the chassis or body.
Using a Digital volt ohm tool check both the batteries rested voltage and charge voltage at idle and then by increases the engine speed to 2000 rpm.
Old Sep 11, 2020 | 02:58 PM
Armyrules2's Avatar
So I've checked for DTCs, there are none. I've replaced and cleaned the terminals on the battery. The battery is charging at around 13.5 volts. And I will have to check the ground wire.
Old Sep 11, 2020 | 03:02 PM
Did you use the proper Diagnostic tool as I mentioned?
Also you did not tell me the rested battery voltage nor the specif rates of charge again as I mentioned??
Old Sep 11, 2020 | 03:04 PM
Armyrules2's Avatar
Yes I used an Innova scan tool. I still have to check the resting battery voltage.
Old Nov 15, 2022 | 12:13 AM
Make a way's Avatar
Hey did you ever fix the issue? I'm having the same problem.
Matthew Wood
Mar 8, 2020 03:52 AM
Withap
Mar 11, 2019 01:50 AM
BUBBA87
Aug 28, 2014 09:35 AM
mattattack811
Jan 8, 2014 03:07 AM
FrankB5
Jan 1, 2014 12:33 AM
