2.3L Head Bolt Torque/pattern...
Old Jul 2, 2007 | 03:43 PM
mazda6guy7's Avatar
Default 2.3L Head Bolt Torque/pattern...
Hey folks. I am working on putting a new cylinder head in my 03 6i (2.3L,Auto). I can't find the specs for the engine ANYWHERE! Does anyone know where to find the tightening sequence and torque specs for this engine? Or does anyone know this information? Help is much appreciated!
Kyle
Old Jul 2, 2007 | 07:36 PM
babyhuey's Avatar
Default RE: 2.3L Head Bolt Torque/pattern...
Here are some diagrams and specs out of the OE shop manual mazda6guy7.
[IMG]local://upfiles/1377/4A5F1A290C0F47D9A595318986F900A8.gif[/IMG]
First is measuring the head bolt to ensure that it has not been over stretched.
[blockquote]
Replace any that exceeds maximum length.[/ul][/blockquote]
[blockquote]
[ul]Length[*]
149.0—150.0 mm {5.86—5.90 in}[/ul][/blockquote]
[blockquote]
[ul]Maximum[*]
150.5 mm {5.92 in}[/ul][/blockquote]
[IMG]local://upfiles/1377/5EE309B814894228887F9BFE5BF582BD.gif[/IMG]
Tightening pattern starts at center rear bolt, then center front bolt and then in a spiral pattern outward. 1-10 in diagram below. Below is torque sequence. Last two are in degrees.
[blockquote]a. Tighten to 5.0 N·m {51.0 kgf·cm, 44.3 in·lbf} [/blockquote]
[blockquote]b. Tighten 13—17 N·m {1.4—1.7 kgf·m, 10.0—12.5 ft·lbf} [/blockquote]
[blockquote]c. Tighten 44—46 N·m {4.5—4.6 kgf·m, 32.5—33.9 ft·lbf} [/blockquote]
[blockquote]d. Tighten 88°—92° [/blockquote]
[blockquote]e. Tighten 88°—92° [/blockquote]
Old Jul 3, 2007 | 07:08 AM
mazda6guy7's Avatar
That is exactly what I needed! Thank you!
Old Jul 13, 2007 | 03:09 PM
mazda6guy7's Avatar
Cananyone tell me if there is a tightening sequence/torque spec for the metal "brackets" that hold down the two cam shafts? If so what are they?
Thanks!
Old Jul 17, 2007 | 02:07 PM
mazda6guy7's Avatar
Anyone??
Old Jul 17, 2007 | 07:29 PM
babyhuey's Avatar
Missed that one on the 13th mazda6guy7. You are meaning the camshaft bearing caps?
Camshaft Installation Note
[blockquote]1. Set the cam position of No.1 cylinder at the top dead center (TDC) and install the camshaft.[/blockquote]
[blockquote]2. Temporarily tighten the camshaft bearing caps evenly in two or three steps.[/blockquote]
[blockquote]3. Tighten the camshaft cap bolts in the order shown with the following two steps.[/blockquote]
[blockquote]a. Tighten to 5.0—9.0 N·m {51.0—91.7 kgf·cm, 44.3—79.6 in·lbf} [/blockquote]
[blockquote]b. Tighten to 14—17 N·m {1.5—1.7 kgf·m, 10.4—12.5 ft·lbf} [/blockquote]
[IMG]local://upfiles/1377/DBB9C4A0E62B476AA9415A21C4B5F567.gif[/IMG]
Old Jul 19, 2007 | 12:17 PM
mazda6guy7's Avatar
You have been so helpful thank you!!!!
fender_bender289
Dec 28, 2010 03:18 PM
mrich912
Sep 30, 2010 03:01 PM
ddzc
Oct 7, 2009 09:09 AM
5speed08
Dec 21, 2008 11:42 AM
ginman999
Jan 9, 2006 10:17 AM
