194 socket?
The right front parking light on my 2006 Mazda 6 does not illuminate. This is the bulb that is in the same fixture with the high-beam headlamp. (I have seen it described as the "194" light.) What does the socket for the parking light look like? I removed the back cover for the headlight and reached in. Finding the high-beam was easy. The closest wiring to the high-beam headlamp was sitting in there loose. It had only a little black, "P" shaped device at the end of the wires. No light bulb was in the device, which seemed to have sockets on either end. The W5W bulb did not fit into either end of this device. I do not know if this device is the parking-light socket; it's just the closest one to the high-beam. There is not a lot of room between the headlight and the washer reservoir, so I cannot do much visual exploring. All I can do is feel around in there for the various wires. Does anyone here know what the parking-light socket looks like? TIA
Yes, the left parking light does work. Because of the tight clearances behind the headlights, I was hoping to find a photograph of the light socket, so I would not have to get in there, especially during this cold winter weather.
