06 mazda 6 sedan radio removal
Old May 31, 2006 | 09:12 PM
cadillac94pimpin's Avatar
Default 06 mazda 6 sedan radio removal
I have know idea how to remove the old radio. I plan on installing a bass system in my girlfriends car, but i have no idea how to remove the stock unit. i will be using an rca output converter behind the radio and running the remote wire to an acc wire back there also. PLEASE HELP! or direct me to link that can THANKS!!
Old Jun 1, 2006 | 04:28 PM
trouble's Avatar
Default RE: 06 mazda 6 sedan radio removal
You can run the line output convertor on the rear speakers. Not to mention if you have the bose system you can just tap into the stock sub..
Old Jun 1, 2006 | 06:11 PM
sstlaure's Avatar
You'll have to pull the cupholder, ashtray panel, & PRNDL bezel before removing the radio
1) Remove cupholder panel by pulling straight up on the panel (works best if you pull up on the park brake handle side first.) There are no fasteners to break, it should just pull up.
2) Detach the 2 tabs between the cupholder panel and ashtray panel. They are on the edge that mates between the 2 panels, you may have to jam a pen or some other small object into the tab to release the 2 panels from each other (the 06 is much easier than the 04/05.)
3) Unscrew your shifter **** (Auto or stick)
- If auto, leave the PRNDL bezel snapped into the ashtray panel, you'll need to unplug the 2 bulbs that light up the PRNDL as well as the cigarette lighter socket. (bulbs twist 90 degrees and pull, socket you need to disengage a couple of tabs before the plug will pull out.) Once they are disconnected, you should be able to pull out the ashtray and PRNDL bezel together (you have to take the trans out of Park and put it at about mid-travel fore/aft (N) to get the bezel to clear the shifter stalk.
- If stick, you should be able to remove the ****, then disconnect the lighter socket and pull the ashtray panel out
4) Remove 2 screws along bottom edge of radio attaching it to Instrument Panel
5) Pull straight out of the IP on the radio and it should pop out of the dashboard.
Old Jun 7, 2006 | 05:34 PM
Thank you sooooo much. I hope its just as easy as it sounds. Ive done plenty of other cars but this one i didnt know where to start.
Thanks again.
MarinerMazda10
Jul 21, 2013 10:08 AM
rspi
Jul 1, 2013 09:28 PM
lucky777
Dec 30, 2011 11:37 AM
pramodkotwal
Sep 13, 2006 10:48 PM
bwhitehfb
Mar 27, 2006 12:05 PM
