'05 Mazda 6 Clutch issue (I'm not a clutch guy)
Old 10-20-2017, 01:06 PM
wearules's Avatar
Default '05 Mazda 6 Clutch issue (I'm not a clutch guy)
One day out of the blue the clutch pedal went straight to the floor and wouldn't come up. Turned out it was a bad slave cylinder. I changed that and bled it. Now it's getting good pressure on the pedal. However, while it will still go into and out of gears smoothly while the car isn't running, I can't get it in any gear while the car is running. When I bled the slave cylinder, I went until fresh fluid was coming out and kept the master topped off... no air is in the lines. If I have it in gear then start it, it doesn't stall... in fact I can even drive it in that gear (1st or 2nd), I just can't get in into or out of any gears while it's running. Whatever gear (1st or 2nd) I start in still feels like the clutch pedal did before this whole incident as far as taking off. Any ideas?
Old 10-21-2017, 04:18 AM
get someone to pump the clutch pedal with the engine running, while you look at the slave cylinder, check to see its got full travel.
Burnout
09-28-2013 09:20 PM
bluesway
08-09-2011 11:36 AM
kyleagrant
04-29-2009 12:05 PM
shannonekermans
05-06-2008 11:27 AM
dannysmazda
04-22-2006 02:48 AM
Quick Reply: '05 Mazda 6 Clutch issue (I'm not a clutch guy)
