04 Mazda 6 cranking, not firing up after new alternator.
Old Oct 29, 2020 | 10:37 PM
PMENDRES's Avatar
Default 04 Mazda 6 cranking, not firing up after new alternator.
I was driving home the other night and both my low beams blew out and I had my battery light come on. I switched on the high beams and got home quick. I woke up the next day and it started up fine battery light still coming on so I had the battery and alternator tested. They said battery is good and the alternator is on the low end and probably on its way out. I went out today to go pick up the alternator and the car won't start. I finally got home with the alternator and replaced it. The starter will crank but the car will not fire up.
things I've tried.
New plugs, New coil, checked the fuel pump it is fine.
Also, I can roll start it and she is fine..
Thanks in advance.
Old Oct 30, 2020 | 05:23 AM
Did you disconnect the battery before touching the alternator?
Old Oct 30, 2020 | 12:28 PM
PMENDRES's Avatar
Yes, the battery was completely out of the car.
Old Oct 31, 2020 | 05:09 AM
Have you gone thru every step you took for removal to confirm everything is plugged in?
Old Oct 31, 2020 | 05:19 AM
PMENDRES's Avatar
Yes, I have. I can roll start it and the alternator is charging fine.
Old Nov 1, 2020 | 04:08 AM
Check the wiring to the starter motor, both the heavy battery feed & the small wire to the solenoid.
Also check ALL the fuses.
Old Nov 1, 2020 | 06:13 AM
retired racer's Avatar
Sounds like main power feading issue cables from the battery make sure you have good ground frame and engine
Old Nov 1, 2020 | 09:43 PM
PMENDRES's Avatar
I forgot to say I have checked the grounds, all fuses(even ones that don't matter), and all relays.
Jeff Brandwagt
Apr 14, 2017 09:43 AM
BengalBrad
Apr 1, 2015 08:20 PM
Jprotege
Dec 10, 2011 08:15 AM
zilla
Dec 23, 2010 11:33 PM
fabemurphy
Mar 10, 2006 12:33 AM
