transmission is driving me insane.
The transmission was hard shifting and doing all the weird things that would indicate it's having a computer issue. so i sent it off to get fixed. got it back, plugged it in. worked for like a day then started doing the same **** for like 10 minutes. then it just forgot that it had gears. it's like it's in neutral all the time. doesn't matter if it's in neutral, drive, park, reverse, the only thing it'll do is try and inch forward a bit and that's it. i figured i'd change the filter and the trans fluid, so i bought a filter/trans fluid/20 new bolts. changed everything, no difference.
i'm guessing that something electrical is amiss. i'm hoping maybe somebody here will have some insight because i'm ready to just set the car on fire and call it a day.
