Timing chain replacement
Old Jul 12, 2020 | 12:02 PM
Hoglodge's Avatar
Default Timing chain replacement
PANIC. My Mazda 5 has just developed the timing chain rattle. If I’m going to change the tensioner I may as well change the lot. Are there instructions anywhere on how to change it? I believe the timing marks won’t be a problem. There’s no Haynes manual and the owners workshop manual doesn’t help.
Old Jul 13, 2020 | 08:24 AM
There are no timing marks. You need specialised timing tools to lock the cams & crank.
Old Jul 14, 2020 | 02:26 PM
Hoglodge's Avatar
Thanks for that it’s saved me a lot of swearing. Mazda 3 locking kit is a tenner on eBay. Any idea where I can get a Mazda5 kit from. Is it the same as 2.0 Mazda5?
Could it be be that it’s only the tensioner thats simply giving up at 80k miles and the chain is OK. FSH.
Old Jul 16, 2020 | 06:26 AM
Same LF series engine. Also, you must replace the lock washers on the crankshaft. Replace the tensioner, guides & VVT actuator while you're in there.
epontt
Mar 26, 2018 04:11 AM
Peter Jones
Apr 4, 2017 04:05 PM
dogwars
Oct 29, 2011 09:19 PM
rm64
Aug 12, 2010 07:15 AM
kasteer
Apr 1, 2010 08:14 AM
