Mazda 5 tappets
Hi, looking for some advice regarding Mazda 5 tappets, doing a refurb on engine and mixed up original tapper location. Any advice on where to find the correct order. Looked online no luck.
It may help in the future to post the year and engine size and type (fuel used) for better answers to service questions.
general tappet installation after mixed up: Unless you can identify by way of the wear pattern and match it to the cam lobes you are basically SOL. I would look carefully at each one and see if there is any unusual wear patterns If not then you are not likely to have mechanical problems or damage to camshaft lobes?
I recommend use an old egg carton and mark the holder corresponding to where you removed parts from.
Thankyou for the quick response. Yeah messed up big time. It’s petrol 2008 1.9. Upon checking there doesn’t seem to be much difference in wear pattern. My question now is what symptoms/sounds should I look out for when starting. Hopefully none but just in case.
On a side note maybe use some engine assembly lube (Molybdenum disulfide (or molylube) either the tappets face or the cam lobes just as an insurance measure and more piece of mind?
my thoughts DON"T WOORY ABOUT IT!!!!
Jim_96
Dec 28, 2019 11:35 AM
