Ground locations
Old Sep 27, 2022 | 06:12 AM
Jackb93's Avatar
Default Ground locations
HI - does anyone know where and/or how to access the ground in the luggage compartment.
The one for the reverse lights?
Old Sep 27, 2022 | 08:04 AM
pkthomas's Avatar
There is one on the left side behind the side panel about halfway up to the window about a third of the way forward of the wheel well. I am pretty sure there is one in the same position on the right side. You have to remove the panel from the back to get to them. I used the left one for backup sensors.
Old Sep 27, 2022 | 10:30 AM
Jackb93's Avatar
thanks for reply @pkthomas - have an issue with my bulb not working but the sensors are working when its removed,. i suspect this is the issue!
Are the panels easy to remove?
Old Sep 27, 2022 | 12:28 PM
pkthomas's Avatar
You have a Mazda5 not a CX-5, correct?
Start with the rubber molding around the lift gate opening. There are some screws hidden behind little covers for the optional cargo cover and One of two other spots. There are also several clips that will need to be popped.
Old Sep 27, 2022 | 03:41 PM
Jackb93's Avatar
@pkthomas Correct i do have a Mazda5 - ok great thanks - ill give it a go. I have a UK model but this can't be too different to US model.
Eleo
Apr 10, 2023 06:18 AM
bangerdemon
May 17, 2021 03:50 PM
hern615
May 18, 2011 07:29 PM
zorbathegreek7
Feb 16, 2009 10:55 AM
sharee
Sep 19, 2008 12:01 PM
