ECU Reset
Old Sep 18, 2010 | 09:01 AM
klc28's Avatar
Default ECU Reset
According to my owners manual, an ECU reset needs to be performed after an oil change in a Mazda 5 Diesel Sport.
Am I right to say this can be done by disconnecting the battery and pressing the brake 10 times (to discharge any stored voltage)?
Does any other dance need to be done for a simple oil and filter change? Your advice is appreciated.
Old Sep 22, 2010 | 02:32 AM
NickC's Avatar
As far as I know you have to reset the ECU on diagnostic equipment. Disconnecting the battery etc. may clear the fault memory but it won't reset the DPF.
Old Sep 23, 2010 | 10:16 AM
klc28's Avatar
Thanks for alerting me.
It looks as though I'll need an IDS or Carman tool for that...
Are there any alternatives to that?
The more hoops I am made to jump through, the more convinced I become to leave the circus.
Old Sep 23, 2010 | 11:25 AM
NickC's Avatar
I've a Texa Navigator which won't reset it, as yet. I'm going down to my local supplier in a few weeks time to try a few different brands of diagnostic tools to see if any will do the job. Their rep owes me the odd favour
Old Sep 23, 2010 | 05:07 PM
klc28's Avatar
I need to find some indies that have the tools to do the reset.
The dealer is quoting £140 to do an oil and filter with the required reset. That is beyond a joke. It's more like a mugging when you consider other cars get this task done for less than £35. Mazda may see my money in the short term...
Old Oct 10, 2010 | 07:45 PM
klc28's Avatar
Has anyone reset their DPF doing this? Does it work on the 5?
http://www.cdn.dk/mazda6/tips.htm
Old May 5, 2012 | 12:27 PM
Kakhaber's Avatar
So...My car is 2003 Mazda 6 3.0L V6 S (AT).I have problem with ECU,ECU number is "ECU PCM Brain Computer Engine BDD3 AJ58 18881 G 3.0L V6 S ECM".The thing is that Ecu's one of the cheap/micro scheme burned,and because of this one of the cylindrs stopped working(but car is still running).My question is next:Is there any difference and if it is what difference is between 2.3L ECU's cheap and V6 3.0L cheap???Can I use 2.3L ecu cheap for V6 3.0L???
SORRY FOR MY BAD ENGLISH I HOPE YOU CATCH WHAT I SAID
Donna K
Jul 12, 2015 05:32 AM
oscar220
May 5, 2012 12:29 PM
speedy123
10
Feb 25, 2012 10:50 AM
Lar3
Dec 9, 2010 06:44 AM
drmaltby
Oct 17, 2006 03:55 PM
