Crank case pressure
Old Oct 26, 2025 | 02:23 PM
paulamos69.pa@gmail.com's Avatar
Default Crank case pressure
Lot of pressure comes out of oil fill cap. I changed the PCV and no change. No oil smoke from tailpipe and car runs fine, no missing, no hesitation, just a burning oil smell when I get off the highway. Changed the valve cover gasket also. Can't see where it could be leaking. Any suggestions?
2012 Mazda 5 Grand Touring 2.5. 133,000 miles
Old Oct 26, 2025 | 05:30 PM
We’ll have no idea what Mazda you have or other important information like engine size year and miles
but this it normally is normal at least on Skyactiv engines. Older and high mileage engines then more information may be needed and maybe recommendations on what test to perform ?
Old Today | 10:12 AM
dmares01's Avatar
2013 Mazda 5 Touring with 198,000 miles
I noticed as well that removing the oil filter cap with the engine running results in a lot of pressure. Some small oil droplets will come out. My valve cover gasket is sleeping and that is in the list of things to replace but after noticing the pressure wanted to make sure nothing else was the root cause of the gasket seeping.
If needed I can attach a video of the behavior and sound it makes. My engine isn't a skyactiv engine so not sure if the other threads apply here
Old Today | 10:23 AM
Its normal on Mazda Skyactiv engines and both non and Skyactiv Mazda unless you are burring oil , or feel a loss in power. In which case do the basic compression test and better a leak down test.
Youtube of a perfectly running and health checked Mazda Skyactiv engine.
https:www.youtube.com/watch?v=j3PkxjptFkM
https:www.youtube.com/watch?v=vlUYg4CVDZU
Old Today | 10:33 AM
dmares01's Avatar
Edit: I see you said both skyactiv and non skyactiv. Ignore me!
I don't believe me engine is a skyactiv although I could be wrong. Everything I can find on the engine has always just said 2.5L L4 DOHC 16-valve but nothing about skyactiv.
The only skyactiv engine I know of for these was the 2.0 liter skyactiv engine
Old Today | 10:36 AM
Well the VIN would be the best way to know exactly what you have but here is a little more information universally posed but not necessarily epirically accurate or fact checked.
Skyactiv - Wikipedia
Old Today | 10:39 AM
You can also do a vacuum check that may indicate more about the state of health of your engine.
If you had valve stem seal or valve guide issues you would not have a steady reading on the needle.
http:www.youtube.com/watch?v=3RfAzHGZKH8
Old Today | 10:40 AM
dmares01's Avatar
Good call. The vin shows the 2.5L
VIN: JM1CW2CL6D0154389
Old Today | 10:41 AM
dmares01's Avatar
I will add that to the list of projects for this month. Always good to have more info
Old Today | 11:13 AM
This may help you?
Online Mazda Parts Superstore | OEM Parts Online
Your VIN indicates a Skyactiv (unconfirmed) engine.
imjamesscott
Jun 3, 2014 08:56 PM
FrankRamizi
May 18, 2011 10:18 AM
jeyssika
Jul 27, 2005 06:15 PM
rjdmp
Jun 10, 2005 10:01 PM
