Abs issues and more
Hey everyone. I’m having issues with my 2009 Mazda 5.
The wheel bearing went on the front drivers Side so I replaced it. After that the abs light has been on all the time.
I assumed i damaged the abs censer so I replaced it.
still the same issue.
So I replaced the one on the pass side.
Well now the abs light goes out but after driving for 2 min the abs light comes back on but....
the e-brake light comes on
and the steering wheel ! Light also comes on and then I lose power steering.
If i shut the car off and restart it will go away but then come back a very short time after.
1 I know I put the bearing in the right way
2 my issue makes the car underivable
3. Before changing the wheel bearing some times when putting on the brake you could hear a clicking sound ( the abs kicking in ). It only did it occasionally
4 I’ve checked fuses and relays to make sure they are good
anyone have any ideas I’m at a loss here
I did when the problem first started. I thought my scanner would save them as it’s done in the past. So I cleared them. And for some reason my scanner did not save them.
Anyways I pulled the pass side tire off and all the rest of the goodies there to look at the back of the bearing it was caked in grease so I cleaned it up
I then took the car for a ride. The abs light is still on but the rest are not. So I’m going out on a limb here and going to say the drivers side is most likely the same and causing the censer not to read.
Will update tomorrow after I pull the wheel and have a look
MAS7873
Nov 6, 2015 01:14 PM
