2014 Mazda 5 engine timing.
Old Jul 17, 2019 | 11:06 PM
  #21
situation519's Avatar
Nope. No alignment pins nor a crank pulley key. See what I've been struggling with now? The alldata diy program has all the same pictures as the workshop manual.
Old Jul 18, 2019 | 06:45 PM
  #22
Does it look like the cams are in the correct position before timing is set again
Old Jul 20, 2019 | 08:10 AM
  #23
From what I can read in regards to replacing the VVT sprocket on the intake cam, it makes no difference once you use the alignment plate.
Old Jul 20, 2019 | 06:02 PM
  #24
So the cam gears look correct in the picture? I just thought the vvt gear had to have a specific position, but I guess I'll chance it. Thank you friend.
Old Jul 21, 2019 | 12:26 PM
  #25
I also wanted to know if the cams looked like they were in the correct position.
Old Jul 24, 2019 | 10:25 PM
  #26
Um, so how does it look?
Old Jul 25, 2019 | 05:09 AM
  #27
As far as I'm aware, if you use the alignment plate then its all fine & dandy.
Old Jul 26, 2019 | 08:40 PM
  #28
So I got it finally. I decided to use some nail polish I borrowed from my friends wife to make some timing marks on the cam gears, as well as the harmonic balancer pulley. I got the Ford/Mazda timing tool from AutoZone, put the plate in the cam slots, used a longer bolt than came in the kit for the crank stop, and torqued everything down. Made 2 full revolutions to set the timing after and all the marks lined up exactly where they were supposed to. Thanks for helping Grim reaper. I think I speak for many of us when I say I'd love to throat punch the engineer who designed this motor with no alignment pins for the cams or the crank pulley or timing marks, lol.
UseYourNoggin
May 24, 2013 08:58 AM
kinni420
Jan 28, 2013 03:08 AM
mazda99
Aug 13, 2008 04:18 AM
homeflash
Apr 4, 2008 11:55 AM
