07 mazda 5 wheel bearings.
Old Jul 14, 2022 | 04:13 PM
Hardwoods30's Avatar
Default 07 mazda 5 wheel bearings.
I have an 07 Mazda 5. I was told that they 07 Ford Freestyle rear wheel bearings should fit. Is this true?
Old Jul 15, 2022 | 08:29 AM
pkthomas's Avatar
I don't think it would work. We had an 05 freestyle and still have a 2010 5. Totally different platforms. I looked at rock auto and there are no rear bearings listed just the hub assembly. The hub with a bearing is not that much more than just a bearing and you don't have to press anything in our out. The interchange on rock auto only lists the 5 and 3 as interchangeably. Not even the very similar focus is listed. The 5 rear suspension is from the Mazda CX-7 and not even it is listed.
Old Jul 15, 2022 | 11:13 PM
Thank you for the insight.
Old Jul 24, 2022 | 01:02 PM
helendenizer's Avatar
good points to mention
Old Jul 30, 2022 | 07:20 AM
huesmann's Avatar
Generally, if a part will fit multiple cars, you can look up the part on RockAuto, click on the part number, and it'll pop up an interchange list, e.g.:
FORD FIVE HUNDRED 2005-2007
FORD FREESTYLE 2005-2007
FORD TAURUS 2008-2009
FORD TAURUS X 2008-2009
MERCURY MONTEGO 2005-2007
MERCURY SABLE 2008-2009
RA only shows the rear hubs interchanging between 2004-2014 Mazda 3 and 2006-2015 Mazda 5.
The Freestyle also uses hub assemblies anyway, just like the 5, and they're not that much cheaper than the ones for the 5.
Auggie
Mar 2, 2021 02:17 PM
pratibha
Sep 7, 2009 06:02 AM
mbariesheff
Aug 30, 2009 05:23 PM
harling01
Aug 30, 2007 07:25 AM
sleeper
Jan 5, 2007 06:21 PM
