transmission fluid change cost
Old Jul 23, 2013 | 03:24 PM
Marc Castro's Avatar
Default transmission fluid change cost
does anyone know how much is the transmission fuid change at mazda the dealer ?
i went to pep'sboys to change my transmission fluid and they said they cannot change the fluid and i should go to the dealer.
so i am afraid to go to the dealer because i know they will charge me a lot of money.
my car is a mazda 3 2011 60k miles
Old Aug 3, 2013 | 12:57 AM
slaphappy's Avatar
I was just there earlier this week. The price I was quoted was $189. Roger Beasley Mazda in Georgetown, TX
-slaphappy
Old Sep 27, 2013 | 04:05 PM
GEEBOSS's Avatar
Talking fluid change
Is you car a manual or automatic transmission?
I'm not a grease monkey but at 63 I looked up a youtube video a googled a how to and did the job myself and had a neighbor help with the measuring as the fluid came out. Put in Redline Synthetic D4 fluid 3 qts at a time, bought 4ft clear tubing at HomeDepot 3/8 in inner diameter. Clear 15 qt tub, 3/8" Drive Hex Bit Socket, long funnel to transmission fill tube. 1 1/2 hr later job done cost under $120 vs dealer at $260 for synthetic fluid change. If you can change your oil you can do this. Drain out 3 qts from the pan replace the bolt and fill the 3 qts...hook up the clear tube to the silver tuna can like pump and start your car have a friend hold the tube in the tub and shift to netural, reverse, drive to expell out 3 more qts of fluid turn off motor and fill repeat again till fluid drains red and cut off engine hook up hose clamps tighten splash sheild and run engine to operating temps and check dip stick fluid level top up if necessary but don't over fill.
Last edited by GEEBOSS; Sep 27, 2013 at 04:07 PM. Reason: automatic transmission instructions
Old Sep 28, 2013 | 06:21 AM
There's no problem doing it yourself, ( assuming its a auto) but you must use genuine Mazda MV ATF.
csteve300
Jan 6, 2013 02:27 PM
RubberSalt
Sep 24, 2009 06:40 AM
pgapro112
Apr 24, 2009 11:11 PM
mdamico
Mar 2, 2008 02:52 PM
S1CkM6
Jun 25, 2006 06:40 PM
