95 protege Transmission fluid change?
Old Sep 23, 2009 | 06:58 AM
RubberSalt's Avatar
Default 95 protege Transmission fluid change?
i drive a 1995 mazda protege 1.5l automatic
I've had it for 3 years/ put 36k miles on it -I've never changed it (currently has 163k miles)
I'd like to change/flush the fluid in my tranny but im not sure how much i need, type of fluid i need, and i'd like to know the recommended way of changing it, i siphoned some out, it was a dark, similar to mazda on the top left corner of this website.
Should i flush the system, siphon it out, or some other method?
What type of fluid do i need?
How much fluid do i need?
Old Sep 23, 2009 | 09:15 PM
hixx's Avatar
Manual or automatic? They both have drain plugs on them. The manual trans holds 3 quarts and the oil it uses varies depending on where you live. They generally come with ATF but in hotter climates a 5/20 motor oil is better for the bearings. The owners manual should give that info.
Old Sep 23, 2009 | 11:34 PM
RubberSalt's Avatar
It's an automatic, I don't have the owners manual. It also has 163k miles on it.
Old Sep 24, 2009 | 06:40 AM
hixx's Avatar
There are 3 options. Remove the pan and change the filter/fluid. Remove the drain plug and do a partial fluid change or take it to a shop with a flush machine. Only a flush machine will get all the fluid out.
Marc Castro
Sep 28, 2013 06:21 AM
pgapro112
Apr 24, 2009 11:11 PM
mdamico
Mar 2, 2008 02:52 PM
Sirob
Jul 21, 2006 06:35 AM
S1CkM6
Jun 25, 2006 06:40 PM
