Tire Size
Old Dec 15, 2007 | 09:19 PM
MrSpike118's Avatar
Default Tire Size
Hi all, tried to find it on the site, but I have a 2008 Mazda 3 S. This is my OEM tire size: 205/55-16. What is the widest size I can go? 215/50-16? Just wondering what all of you have done. Thank you. Brandon N.
Old Dec 15, 2007 | 10:26 PM
sstlaure's Avatar
Default RE: Tire Size
I ran 225/45R17 on mine with no issues (17x7 rim 60mm offset)
I believe the max recommended width for the stock 6.5" wide wheel is a 215.
Old Dec 16, 2007 | 06:43 AM
I too am running 225/45-17's w/no issues. 215 is widest to safely run on a 6.5" wheel, A reputable tire shop would nottry to go bigger from all I've read.
Some are running 235's but need morenegative offset in their wheels (i.e. +45/+42mm) and you start getting into fender lip rolling, issues w/strut clearance (where the extended offset comes in,) etc.
Going to a 215/50 there will be a -1.685% in revs/mile. Translation: Your speedo will readhigh by over 1mph @65. (Speedo= 65. Actual= 63.9mph.)
Your best plus zero choice is the 225/50-16 to maintain proper circumference, but again, your wheels are only 6.5" wide.
Damned if ya' do, damned if ya' don't. Same problem I ran into. I ended up getting 7" wheels.
If you have to do that, go to a 17" wheel (or 18" is weight isn't a concern for you) w/225/45's.Anything over 7.5" wide on a 3 is a waste and will just add to the unsprung weight.
Old Dec 19, 2007 | 03:38 PM
MrSpike118's Avatar
thank you very much guys!
Old Dec 29, 2007 | 04:31 PM
Kuth's Avatar
I have a question similar to this one. I just got an 08 M3 Touring 5-door. It came with the standard 17s. Was wondering, can I go down to 16" steel wheels for winter tires? Will 16s clear the brakes?
Old Dec 29, 2007 | 04:37 PM
Simple answer is, Yes! But no lower.
Really, this is a common question and though I have no need to do it myself it will work. No clearance issues w/16's. Just make sure, and I say this to anyone replacing the OE's w/something else, to be careful of the OE offset (+52.5mm) and stay as close to that as possible. Fewer handling, tracking and clearance issues that way.
Old Dec 30, 2007 | 07:35 PM
VanSin23's Avatar
I am running 18 x 7.5 with a +45 offset and the recommended tire size 225/40/18. If you go 18, get this tire size. It is stock size on speed 3's and it is only .1 percent different so, basically none at all.
andrew
Apr 16, 2007 06:06 PM
sinktip
Apr 9, 2007 06:43 PM
parkmazdajon
Mar 8, 2007 05:23 PM
dewthenet
Nov 28, 2006 09:17 PM
stan2005
May 2, 2006 12:31 AM
