Springs
Old Feb 16, 2011 | 08:57 PM
Aubrey's Avatar
Default Springs
Does anyone know the spring rates between the 4-door, 5-door, and Speed? I thought I saw somewhere that the fronts where the same for the 4-door and 5-door but, the rear 5-door springs would sit slightly higher when installed in a 4-door.
The reason I ask, I wonder if I could find some Speed3 springs cheap from someone that went with aftermarket springs. Just not sure if they'd make it sit @$$-high.
Old Feb 17, 2011 | 11:27 AM
djs2571's Avatar
If they are the same physical size they shouldn't sit noticably different. I'd be concerned that they are a different rate, and different length - since different struts are used there could be some big differences between the normal and speed models.
There's also less than 50# difference between the 4 door and the 5 door, so the rears shouldn't make a difference in height either.
But looking at the mazda website, the 5 door is 3064# with the manual, 3124# for the auto, and the speed 3 is 3272#.
About 60/40 weight distribution, so 1900# on the front axle, 100# difference on 1900# isn't a whole lot - so it shouldn't sit noticably different than stock. Again, assuming the overall spring length isn't different as well.
Old Feb 17, 2011 | 12:49 PM
Aubrey's Avatar
Thanks.
I would change the struts and shocks as well. I was thinking that if I put the Speed springs under it that it would lower it a little and give it a sportier feel. If I could get them from someone that swapped theirs out then it would save from buying brand new lowering springs.
Rice Burner
Suspension
20
Feb 9, 2007 04:49 AM
chefmaster25
Jan 19, 2006 12:38 PM
bassment_3
Jul 13, 2005 01:13 PM
osumx5
Jun 18, 2005 02:25 PM
ImportCarPartsP
May 12, 2004 01:21 PM
