Seatbelt Indicator
Old Mar 27, 2006 | 03:34 AM
kiriakis's Avatar
Default Seatbelt Indicator
New to the forum, and sorry if this has been addressed, but does anyone know how to deactivate this indicator. I'm not a fan of wearing my seatbelt for short trips, and I'd really like to turn off the annoying indicator. Any ideas?
Old Mar 27, 2006 | 06:15 PM
Lev's Avatar
Lev
Default RE: Seatbelt Indicator
Buckle the seatbelt before you sit down and then just sit on the seatbelt.
Old Mar 27, 2006 | 09:36 PM
MikeMzda3's Avatar
or you could just wear ur seatbelt...
Old Mar 28, 2006 | 04:05 AM
kiriakis's Avatar
Logic aside - anything that can be done electronically to deactivate the indicator???? - And yes I do where my seatbelt 99.99% of the time.
Old Mar 28, 2006 | 12:45 PM
MikeMzda3's Avatar
haha dont worry - im not judging you.
but to answer your question, i have no idea.
Old Mar 28, 2006 | 01:52 PM
sstlaure's Avatar
The dealer can deactivate that chime for you. They may argue at first, but I believe there is a TSB out for the deactivation.
Old Apr 4, 2006 | 08:32 PM
babyhuey's Avatar
There is a TSB and here is the link to it. Note that there is also a temporary deactivation procedure that you can do yourself
http://www.finishlineperformance.com.../docs/0005.pdf
Old Apr 4, 2006 | 09:58 PM
Tracker's Avatar
dont know if you can find it but check your switch board and locate something that might hit you towards seatbelt indicator (this is highly unrecommended though)
Old Apr 5, 2006 | 03:10 PM
naxxal's Avatar
I would check under your seat first, there whould be a wire and little connector in the middle, disconnect them and your seatbelt light should hot work, this is the most popular place where you will find it, close to where you buckle your belt, look for wiring, it should be farily easy, If it won't work open up your fuse boxs under your glove compartment and see if there a fuse for it, if you find it just pull it out. Whatever you do its all your decision, no mine, i am only responding your question.
Old Apr 5, 2006 | 04:34 PM
the_gray_mazda6's Avatar
this is for the mazda6... but i believe the 3 is pretty much the same way.
check out and read up on this post... alot of good information and pictures to help you out. https://www.mazdaforum.com/m_7124/mp...lt/tm.htm#8723
MK5
Jun 25, 2007 04:52 AM
Blackout
Jan 15, 2007 01:54 PM
Bushy
Aug 24, 2006 08:52 PM
bdubbs84
May 28, 2006 01:36 PM
louieo
Apr 24, 2006 10:37 PM
