From passenger window problems..
Old Mar 1, 2017 | 09:47 AM
Pangy_23's Avatar
Default Front passenger window problems..
Have a little difficulty figuring out what's going on with my front passenger window. I've checked to see if there is voltage going to the motor and it will only get voltage from the passenger side switch and not the master switch. The motor will not make any type of movement even when I switch the passenger switch. Still trying to figure out if it's the motor or maybe a ground wire problem. Any suggestions?
Old Mar 2, 2017 | 06:11 AM
How many wires go to the motor?
If its two wires, then the polarity will swap between going up & going down.
Have you tried powering up the motor directly?
jhendren
Sep 28, 2022 01:55 AM
HerrKaLeun
Aug 4, 2013 08:34 PM
Alski101
Jun 7, 2011 11:06 PM
punkascii
Aug 10, 2009 05:34 PM
Chucky Cheese
Apr 6, 2007 12:16 AM
