Options...
Options...
If you had a choice between power pulley set or aftermarket intake mani which would you choose as far as performance?
Keep in mind with the exception of Shippo's comments which whom Jesus himself couldn't prove that aftermarket parts actually do increase power at other points besides at or near redline, with the exception of boosting and/or ECU modification. Are manufactures claims hyped..sure..but there is SOME truth to the matter. Keep in mind that "bang for your buck" or Performance:value (or money spent) ratio is a completely irrelevant argument. Value is completely subjective and discretionary to which the term has a different view and definition to every human being on this earth. Point being what I find might be very valuable but you may find it junk. "One mans trash is another mans treasure."
With that being said, which would you choose?
I am not a fan of 'power pulleys'. They under drive items that were chosen to be driven at their spec. If you were going to go that route, might as well go for a skinny and super light wheel and tire package. Or get rid of engine belt driven accessories all together.
I'd lean on the manifold sold since you're dealing with an air pump.
Do you have a big stereo? Doesn't power pulleys slow things down like the alternator---it does not put that much output already especially @ idle.
Does new intake manifold require tuning or will difference from MAF reading be enough?
I am leaning to MAF reading increase in airflow should be OK without tuning.
Long runners = Low end Tq
Short runners = High end Tq
Although I know that we use VLR so that it distributes power equally through the entire RPM band.
Ship. I want to believe you. If you can prove by physics, and math that aftermarket products do not make the claims they say they do and even worse are actually counter productive and damaging to your vehicle. Then Sir, I will quit my job, take a one way flight to your home, front you the money for the best damn lawyer your state has to offer and we shall sue every major car aftermarket product company for false advertising and damages, shut down these companies for the damages they cause and then me and you shall live like kings...Because the feeling that I am getting from you is that this industry is the most lucrative and most scamming of all things since the Pope was in power of the free world back in 1400's...or whatever the time was..
Oh, and maybe I want to **** my money away to make my car as loud a possible and drive up and down my street at 3 a.m. and **** people off. =) I'm just a spoiled little rich kid with money to burn. lol. not.
If i didn't do the power pulleys I was thinking just doing the crank pulley however they want, i think, close to $300 for a claimed 10hp...
Found this for you: Mazda 6 Manifold - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Monoxide is a part time mechanic with a very top notch 4 cyl.
- Long runners = Low end Torque
- Short runners = High end Horsepower
As for all of the noise you've made about my comments, you can twist and distort everything I've said to your heart's delight; the fact remains there is no free lunch. If you alter the intake system of a normally aspirated engine so that it allows for a slight bump in horsepower at WOT, then there are almost 100% odds that mid range torque will suffer by an equal or greater amount. Like it or don't.
Ok, that's fine ship, I'm not distorting anything. I am simply comparing your claims which you claim to be the real truth to manufacture claims which you claim to be false. Would that be correct?
Simple question, based off your fact driven information, which can indisputably not be argued against, do you believe manufactures falsely advertise their products, and to the point where it is so bad, that they are actually taking advantage of consumers, leaving out pertinent information that would actually drive the consumer choice or market?
The amount gained at one area of the rpm zone would be more than the area lost at another rpm zone. This can also have even more gains and less losses with a proper computer tune.
This is the result of modding.
Especially with today's cars, there are many gears with higher revving engines, These days midrange is almost over 3,500 rpm.
In older days, 5,000 was redline, now it's 6,500 - 7,000 rpm.
