No start on 2008 mazda 3
Old Sep 24, 2020 | 11:22 PM
Smith2018's Avatar
Default No start on 2008 mazda 3
I blew my head gasket so I decided to just get a used engine.. while my father was talking out the engine he disconnected the harness wire without unplugging the battery and now while I replace the engine I purchase my ride will not start auto theft light is on I tried reprogramming it but the computer don't seem to catch it what can I do I've heard that you're not supposed to disconnect the harness wire until you disconnect from the battery how can I fix that problem now...
Old Sep 25, 2020 | 06:13 AM
Scan it for fault codes.
Are you using your original ECU/PCM?
Old Sep 25, 2020 | 08:58 AM
Steve Hibbert's Avatar
Default Mazda 3 - won't start
I have a mazda 3 2005. At this time of year whenever the weather gets cold (below 10 degrees C) it refuses to start and the auto theft light stays on. What I do to get the car to start is put the key in the ignition and turn it to position 2. Leave it for 5 mins. It must warm the ignition system. The car always starts after that. I've had the problem for a few years. It is too expensive to fix, but what I do ALWAYS works. I haven't replaced the engine or done any major work, so this fix might not have any effect. It's worth a try, no costs.
Old Sep 25, 2020 | 11:12 PM
Smith2018's Avatar
Yes I have my original ECU/PCM my AT is on.. can a PCM be replaced by a use one well that Even work
Old Sep 26, 2020 | 02:39 AM
Yes you can use a second hand PCM, however it will need to be reprogrammed to your car & your keys.
Best next step is to scan for codes.
wolff645
Aug 13, 2020 08:43 AM
mheber01
Jun 12, 2018 02:46 PM
radars
Oct 3, 2011 02:41 PM
TheGuest
Jan 1, 2010 04:13 PM
michaeld
Jan 18, 2008 05:25 PM
