Mystery Items on my 06 Mazda 3
Old Oct 7, 2018 | 12:53 PM
Jbird007's Avatar
Question Mystery Items on my 06 Mazda 3
I need help identifying a few things on this '06 Mazda 3 I just purchased. The first image is of 2 sensors mounted on a bracket directly in front of the lower grill.
These next 2 images are of a figure 8 shaped rubber retainer above and in front of the air filter housing, and of a rubber bushing that is right next to it.
This is a wiring connector that is mounted just above the cooling fan. Some sort of diagnostic connector maybe?
Last is this clip nut which is on the air filter housing.
I just bought a 2006 Mazda 3 (style I) and there are some things under the hood I cannot identify or figure out what they once did. Any help is appreciated.
Old Oct 8, 2018 | 05:52 AM
The sensor behind the grill will either be for the climate A/C or else the SRS ( Airbags)
The rubber figure 8 is part of the airbox mounting, the rubber bush from memory should have a bolt thru it.
The wiring plug above the fan is definitely not diagnostic, it could be for a different grade spec or overseas model.
Not sure on the nut clip, once gain it may be for another engine, or grade spec or overseas model.
woadito
Nov 7, 2020 08:48 PM
Scottwooton
Mar 4, 2019 05:23 PM
Scottwooton
Mar 2, 2019 02:36 PM
2012pghm3
May 18, 2012 12:26 PM
Gene563
May 22, 2008 05:26 PM
